Importing Yahoo mailbox
  • 7 views
  • Last reply by Toad-Hall
I am having an issue with converting my Yahoo email to Thunderbird. I see I have 6500 emails in my Yahoo email account, but do not see my emails in Thunderbird Inbox.
I have a default view of 10,000 messages but cannot see my first email.
I am having an issue with converting my Yahoo email to Thunderbird. I see I have 6500 emails in my Yahoo email account, but do not see my emails in Thunderbird Inbox. I have a default view of 10,000 messages but cannot see my first email.
I do not know whether you have set it up correctly nor whether you use Pop or Imap. Lots of unknowns at this point.
You need to provide info: What OS do you use? What version of Thunderbird are you using? Is this an imap or pop mail account ? Have you used yahoo to generate an app specific password which you use instead of the ussual password? If not then you need to create one: https://help.yahoo.com/kb/generate-manage-rd-party-passwords-sln15241.html
Do you get any error message ? If yes - post an image of the error. What are current incoming and outgoing server settings - post an image or : Help > Troublshooting Information scroll down to 'Mail and News Accounts' section Post an image showing everything in that section.
If this is a recent/new install of Thunderbird: Have you accessed the Firewall and set up Thunderbird program as 'allowed' ? If no, then please do this first.
Is your computer using a VPN ? If yes, then servers do not like them because they expect your IP address - anything else ...well the servers think someone is attempting to hack the account so they block access. Options - switch off VPN or create a split tunnel for Thunderbird to use.
Info on Imap: https://help.yahoo.com/kb/SLN4075.html
Info on POP: https://help.yahoo.com/kb/SLN4724.html
